Sharepoint Online Connector - running from Flow does not read the current data?
  • November 8, 2024
  • 30 views
hayley.lam
Hi there,
I have a workbench published to FME Flow. In the workbench I have a SharepointOnlineConnector which reads in an Excel Sharepoint spreadsheet, and downloads it to my shared data source in Flow server.
The workbench runs successfully and the output (a table in ArcGIS Online) says it has updated, however the values are all old data.
When I run the workbench manually from Form, the SharepointOnlineConnector reads the current data in the Excel.
Any pointers on how to get Flow to read the current Excel Sharepoint?
kate-safe
Forum|alt.badge.img+7
  • November 13, 2024
Hi @hayley.lam
Thank you for your post!
If possible, are you able to share the workspace that you have created, as well as the job log from both Form and Flow when you run the workspace on the same dataset?
If you do not want to share them publicly here on this post, you can create a support case and someone from our team would be happy to assist you with this issue as soon as possible!
A couple of other things to check:
  • are you running this workspace manually on Flow via the Run Workspace or through another method (automation, schedule, etc.)?
  • if there are any user parameters that allow you to set the dataset path on Flow, does updating those make a difference?
Thank you!
