Revit Locations
  • Mar 18, 2024 12:50 PM UTC
  • 50 views
moatazbellah885
Dears,
If i have Revit Model that has multiple Locations and we need to separate each Location to single Revit file .
Is it possible using FME??
Thanks in advance
jasperwis
Forum|alt.badge.img+19
  • Mar 18, 2024 2:46 PM UTC
Hi @moatazbellah885
With the updated FME2024 Revit Writer this will be (mostly) possible.
In FME 2024, you are able to write family instances.
Set your input Revit model as template for your Revit writer.
Jasper
