Return Boolean Value for workbench
  • Oct 4, 2017 5:20 PM UTC
  • 171 views
dfresh
running on FME server and Cloud, don't want to return any datasets. just want to return a simple true or false,
is this possible in FME?
Best answer by larry
Don't know if this is exactly what you want but the attached workspace published to the DataStreaming service will return true as a string to the caller.
  • Oct 4, 2017 5:28 PM UTC
dustin
Forum|alt.badge.img+36
  • Oct 4, 2017 5:31 PM UTC
An AttributeCreator could be used to return a boolean attribute, based on the values from other attributes. Within the drop down, you will find Conditional Value. You can setup an 'If' statement from there.
dfresh
  • Oct 4, 2017 9:12 PM UTC
I can return output from the Server/Cloud with attribute creator? no?
