rename feature attribute with python
  • Dec 14, 2019 3:20 AM UTC
  • 10 replies
  • 305 views
charry
Forum|alt.badge.img+5
how rename feature attribute with python
Best answer by takashi
Hi @charry, there are at least two ways.
1. Create new attribute, remove old attribute.
def renameExample(feature):
    v = feature.getAttribute('oldName')
    feature.setAttribute('newName', v)
    feature.removeAttribute('oldName')
2. Rename attribute using the FME function @RenameAttributes
def renameExample2(feature):
    feature.performFunction('@RenameAttributes(newName,oldName)')
See here to learn more about FME Functions: FME Factory and Function Documentation
  • Dec 14, 2019 3:41 AM UTC
charry
  • Dec 14, 2019 4:13 AM UTC
ERROR:
Python Exception <IndentationError>: expected an indented block (<string>, line 10)
Error executing string `import<space>fme<lf>import<space>fmeobjects<lf>#<space>Template<space>Function<space>interface:<lf>#<space>When<space>using<space>this<space>function<comma><space>make<space>sure<space>its<space>name<space>is<space>set<space>as<space>the<space>value<space>of<lf>#<space>the<space><apos>Class<space>or<space>Function<space>to<space>Process<space>Features<apos><space>transformer<space>parameter<space><lf>def<space>processFeature<openparen>feature<closeparen>:<lf><space><space><space><space>a=feature.getAttributeNullMissingAndType<openparen><apos>BZ<apos><closeparen><lf><space><space><space><space>if<space>a<openbracket>1<closebracket>==true:<lf><space><space><space><space>feature.performFunction<openparen><apos><at>RenameAttributes<openparen><apos>KD<apos><comma><apos>BZ<apos><closeparen><apos><closeparen><lf>#<space><space><space><space><space><space><space><space>v<space>=<space>feature.getAttribute<openparen><apos>BZ<apos><closeparen><lf>#<space><space><space><space><space><space><space><space>feature.setAttribute<openparen><apos><u5907><u6ce8><apos><comma><space>v<closeparen><lf>#<space><space><space><space><space><space><space><space>feature.removeAttribute<openparen><apos>BZ<apos><closeparen><lf><space><space><space><space><space><space><space>#<space>feature.setAttribute<openparen><apos><u5907><u6ce8><apos><comma>feature.getAttribute<openparen>feature.getAttribute<openparen><apos>BZ<apos><closeparen><closeparen><closeparen><space><lf><space><space><space><lf><lf>'
Factory proxy not initialized
PythonCaller (PythonFactory): PythonFactory failed to process feature
A fatal error has occurred. Check the logfile above for details
charry
  • Dec 14, 2019 4:24 AM UTC
why I Can't execute successfully
  • Dec 14, 2019 4:37 AM UTC
firstly check if you have set the Class or Function to Process Features parameter appropriately.
charry
  • Dec 14, 2019 4:41 AM UTC
First time use PythonCaller, can you provide some detailed operations?thanks
  • Dec 14, 2019 4:42 AM UTC
Then, correct indentations.
charry
  • Dec 14, 2019 8:08 AM UTC
https://docs.safe.com/fme/html/FME_FactFunc/index.html function usage depend performFunction ?
  • Dec 14, 2019 8:49 AM UTC
No, the @RenameAttributes function is an FME function (not Python), and the document you link describes FME functions.
  • Dec 14, 2019 8:51 AM UTC
There are excellent tutorials on Python and FME basics, I'd recommend you to start learning from here.
https://knowledge.safe.com/articles/706/python-and-fme-basics.html
https://knowledge.safe.com/articles/60319/pythoncaller-transformer.html
  • Dec 14, 2019 8:56 AM UTC
Alternatively you can use the AttributeManager transformer or the AttributeRenamer transformer, if you just need to rename attributes.
Of course it's good to learn Python, but it would take time.
