Reader needs access to web service connection
  • Nov 3, 2015 5:09 PM UTC
  • 6 replies
  • 65 views
I have added my web service to FME:
FME Workbench -> Tools -> FME Options -> Web Service Connections -> Web Services...
I have also declared two parameters for the web services (username+password)
Furthermore, my reader uses the GUI type NAMED_CONNECTION [1], so users can set their username and password for my web service. My question is: How can my reader access these values/parameters?
During the open method, my reader parses the mapping file, but it only includes the chosen "Connection Name" and not the password or username.
The values/parameters are stored in FME, I verified that using again:
I thought, maybe FME provides some kind of service returning the values/parameters identified by the connection name and web service. Does such a service exist? Or is there another way to access the values/parameters from a given connection name?
My reader is written in C++
Thank you very much!
ben
[1] http://docs.safe.com/fme/html/FME_GuiType/doc_page...
gisbradokla
Forum|alt.badge.img+27
  • Nov 4, 2015 2:38 PM UTC
Are your username/password parameters already set as published parameters?
I think that is the method to get user interaction on parameters.
  • Nov 6, 2015 12:53 PM UTC
I do not think so. How can I set them as published parameter?
Thanks!
  • Nov 6, 2015 4:23 PM UTC
Thanks!
See:
https://knowledge.safe.com/articles/1287/published-parameter-examples.html for examples
  • Nov 8, 2015 6:26 PM UTC
@jonathan_hrw
Thanks for answering. For my reader it would be much better if I can publish the parameters only using the reader`s metafile (without further transformers etc). Is this also possible?
  • Nov 8, 2015 11:49 PM UTC
Probably this is the answer.
"- If your format has specialized connection parameters, then they should be grouped in a NAMEDGROUP called FME_CONNECTION_GROUP. If the format is used in a context where only connection information is needed (ex. SQLExecutor, Joiner) then only parameters in that group will be shown." -- Metafile Documentation
Takashi
  • Nov 11, 2015 11:35 AM UTC
Takashi
Thanks for sharing this. But I already grouped the parameters and called them FME_CONNECTION_GROUP. Unfortunately, I can see no difference. Using my reader, I can parse the NAMED_CONNECTION field but I only receive the connection name, not the corresponding username+password. Also none other keyword allows me to parse username+password, at least I do not know which one I must use.
