Read SURVEY123 Results with FME
  • Mar 22, 2023 7:02 AM UTC
  • 276 views
dataman
Forum|alt.badge.img+7
Hello everybody,
I want to connect Survey123 and my FME Workbench. I try to get the results of my survey but I just find informations about the create a webhook. So I can only get a new or edited input.
Can I read all the current results with FME?
Thanks!
nielsgerrits
Forum|alt.badge.img+67
The results are written to an Esri FeatureService in ArcGIS Online or Portal for ArcGIS.
Use a Classic reader or a FeatureReader with the format Esri ArcGIS Portal Feature Service, Esri ArcGIS Server Feature Service, Esri ArcGIS Online (AGOL) Feature Service.
Be aware that for downloading the attachments, you need a classic reader. The FeatureReader does not support this at this point, as far as I know.
dataman
  • Mar 22, 2023 9:49 AM UTC
Unfortunatelly it does not work:
  • Esri ArcGIS Portal Feature Service -> proxy Error Max retries with URL. tunnel connection failed
  • Esri ArcGIS Server Feature Service -> proxy error
  • Esri ArcGIS Online (AGOL) Feature Service -> Problem with the JSON token
