Read in FME TEMP variable
  • Nov 23, 2015 3:31 PM UTC
  • 118 views
I am looking for a way to obtain the FME TEMP directory. As far as I know, FME defines the TEMP directory based on 4 characteristics [1]. My question is: Using a C++ reader, can I get the path currently used as temp directory?
Something similar to:
fmeSession_->fmeHome() returns the home directory of the FME
? returns the TEMP directory of the FME.
Of course, I could try to read in the TEMP environment variable by myself (stored in Control Panel | System | Advanced | Environment Variables). But I think using FME for this would be a better solution.
Thanks
ben
[1] FME TEMP variable
Best answer by fmelizard
Sadly this is not part of our API at this point. I can tell you that what we do is look for FME_TEMP as an environment variable, and failing that, TEMP, then TMP, then TMPDIR. ANd if all that fails, we go for c:\\temp on windows and /tmp on unix.
But you can use an @Tcl2("return [FME_TempFilename a b]") (in a performFunction call on FME Feature) and you could then pick out the temp directory from that. And you should delete the file you get back as well.
fmelizard
Forum|alt.badge.img+22
  • Nov 27, 2015 6:48 AM UTC
  • Dec 2, 2015 10:31 AM UTC
Thanks for your answer. Using TCL works good for me.
