RasterReplacer is unable to recognize attachments from ESRI Portal
  • October 21, 2020
  • 7 replies
  • 207 views
Using an Esri ArcGIS Portal Feature Service Reader to read attachments, RasterReplacer fails on the attachment blob with INVALID_FEATURE_CANNOT_READ_BLOB.
Enable Attachments='Y' on the reader, the arcgisonline_attachment{} list is exposed, and arcgisonline_attachment{}.data contains data.
I am able to manually download jpg attachments from Portal successfully. I've tried all the image formats in RasterReplacer against the jpg in Portal.
Any help would be much appreciated. Thanks!
FME 2019.2.1.0, Portal 10.6.1
Best answer by andreaatsafe
kdedovesh wrote:
Hi Andrea,
Thanks for the reply!
Yes, I have tried "JPEG (Joint Photographic Experts Group)", and the content_type is image/jpeg. (screenshot attached)contenttype
No problem, so it looks like the data is not in the standard JPEG blob format as JPEG blobs usually start with the byte marker FFD8, hence the RasterReplacer is rejecting it.
Try first using a BinaryDecoder set with the following parameters:
  • Encoding type to "Base64" and
  • Attribute to Decode to"arcgisonline_attachment{0}.data"
Then use the RasterReplacer and set it to "JPEG (Joint Photographic Experts Group)".
andreaatsafe
Forum|alt.badge.img+12
Hi @kdedovesh​ ,
Have you tried using the "JPEG (Joint Photographic Experts Group)" format for the RasterReplacer?
Can you confirm what the value of the "arcgisonline_attachment{0}.content_type" attribute is when you inspect a feature from the reader?
AGOL_AttachmentInfo
  • October 21, 2020
Hi Andrea,
andreaatsafe
  • October 22, 2020
kdedovesh wrote:
Hi Andrea,
  • October 22, 2020
Thank you very much @andreaatsafe​, that worked!
poalgura
  • October 10, 2021
I got this same issue but with png image formats. Does anyone know how to resolve this one too?
philippeb
Forum|alt.badge.img+20
  • May 25, 2023
You just saved my life! :)
changeofmotion
I’m having the exact same issue as described here, and wondering if anyone can help!
In my case, I’ve put a Binary Decoder in as suggested by ​@andreaatsafe . Unfortunately the issue persists.
I’ve also tried using an AttributeFileWriter after the BinaryDecoder - this outputs jpeg files, but they are all non-readable/corrupt. Attachments on the ESRI portal are absolutely fine.
Any other troubleshooting tips here?
Thanks in advance!
