PythonCaller ArcPy clip_analysis inputs
  • Aug 1, 2017 7:40 PM UTC
  • 162 views
I am trying to modify an FME custom transformer to run the ESRI ArcPy clip_analysis function and I'm not sure how to write the script to read the two input datasets needed for the clip_analysis.  Here is a link to the custom transformer I am modifying.  using-arcpy-for-fme-feature-processing
I have each of the datasets going into the PythonCaller and the fme_feature_type attribute is added and populated when they input into the custom transformer.
import fme
import fmeobjects
import arcpy
def processFeature(feature):
    # Get clipper and clippee FC's and settings from feature attributes
    dataset = feature.getAttribute("pre_clipped")
    arcpy.env.workspace = dataset
    # Set local variables
    inFeatures = "pre_clipped"
    clipFeatures = feature.getAttribute("clipper")
    outFeatureClass = dataset + "/clipped"
    # Execute Clip using clipper and clippee
    arcpy.Clip_analysis(inFeatures, clipFeatures, outFeatureClass)
  • Aug 2, 2017 7:26 AM UTC
What are the attribute values for "pre_clipped" and "clipper" entering your custom transformer when it runs?
  • Aug 2, 2017 3:59 PM UTC
They are fme_feature_types assigned using the attribute creators at the beginning of the transformer workflow.
  • Aug 2, 2017 4:03 PM UTC
I'm sure what I have there is completely wrong. What I'm mainly trying to figure out is how to run an ArcPy clip_analysis using the FME PythonCaller. My issue is that analysis requires two separate input feature classes to run and I do not know how to make it work.
  • Aug 3, 2017 8:04 AM UTC
Perhaps you already know this, but you should consider FME and the arcpy geoprocessing as two completely different and unrelated programs. When you call e.g. arcpy.Clip_analysis() from FME, you're basically pausing FME to start an external program, letting FME only resume when the arcpy procedure has ended.
Some implications are
  • you cannot pass an FME feature object to arcpy, you can only pass the name of a feature class that already contains the feature.
  • calling an arcpy geoprocessing function may take a long time, so in most cases executing it on a per-feature basis should be avoided (unless you only use a single trigger feature).
If you need to perform arcpy geoprocessing on features processed by FME, this could be one way to do it:
  • Read and process the data in FME
  • Write the data using FeatureWriters rather than regular writers
  • Connect a PythonCaller to the Summary port of the FeatureWriter. If you have several FeatureWriters, user a FeatureHolder and a Sampler (sample 1st feature) to only send a single trigger feature to the PythonCaller. This ensures that all the data has been written to the Geodatabase before continuing.
  • In the PythonCaller, execute arcpy.Clip_analysis() with the names of the feature classes used in the FeatureWriter(s)
  • If you need to do further processing in FME, consider the FeatureReader to read the results from the arcpy geoprocessing back into FME.
Hope this helps.
