Problem with wildcards for Filename (multiple) type parameter on FME Server (REST)
  • Aug 31, 2016 10:46 AM UTC
  • 99 views
helmoet
Forum|alt.badge.img+8
Hi, I created an FME Workspace to process one or more files using an FFS reader. If I run it on FME Workbench is accepts a wildcard for the SourceDataset_FFS parameter. Even if I call it from a WorkspaceRunner it runs fine. However, If I post it to FME Server, I get the following response (HTTP/1.1 422 Unprocessable Entity): `_response_body' has value `valueD:\\Data\\FME\\FME%20Server\\Data\\LDR\\1_Secties\\*.ffsUnexpected value "D:\\Data\\FME\\FME%20Server\\Data\\LDR\\1_Secties\\*.ffs" for parameter "value," expected list'
Request url:
`myURL' has value `http://myfmeserver:8080/fmerest/v2/transformations/commands/submit/LDR/Stap_4_BerekenSectiesMetStationing.fmw?token=11111113289cef40e8bc340c3a63b3ff43405b00&detail;=low'
Upload body:
`UploadBody' has value `{ "FMEDirectives" : {}, "NMDirectives" : { "failureTopics" : [ ], "successTopics" : [ ] }, "TMDirectives" : { "rtc" : false, "description" : "LDR autorun LDR_Trigger_Handle_Notification", "priority" : 5, "tag" : "linux" }, "publishedParameters" : [ { "name" : "SourceDataset_FFS", "value" : "D:\\\\Data\\\\FME\\\\FME%20Server\\\\Data\\\\LDR\\\\1_Secties\\\\*.ffs" }, { "name" : "FANOUT_DIRECTORY", "value" : "D:\\\\Data\\\\FME\\\\FME%20Server\\\\Data\\\\LDR\\\\4_SectiesMetStationing" }, { "name" : "DestDataset_MSSQL_ADO", "value" : "GPL" }, { "name" : "MSSQL_ADO_OUT_SERVER_MSSQL_ADO", "value" : "GUHQTSQL1282\\\\TDBMSA" } ], "subsection" : "REST_SERVICE" }'
When changing the parameter type to tekst, it works fine. However, that deprives us from entering valid series of filenames.
mark2atsafe
Forum|alt.badge.img+59
Hi @helmoet
I don't see any existing reports about this, but I've no doubt you are right. Can you file a case with our support team? See safe.com/support - then someone will be able to confirm the problem and let you know when a fix might be available - and if there is a workaround.
Apologies for any inconvenience this is causing
Mark
helmoet
  • Oct 20, 2016 6:57 AM UTC
Aha I see now. I have to put an extra pair of square brackets around the parameter value in the REST call's upload body. Then it works fine.
