Posting to esri portal and feature service
  • Apr 15, 2019 5:52 AM UTC
  • 44 views
hi,
I am new to the esri portal side of things and i am currently have a small issue. i am using a HTTPcaller to post to esri portal.
As far as i understand if i was to manually upload to portal via add item on the portal page this creates a feature service for my data.
my issue is when using fme to upload a shp, gdb to portal the feature service link is not been created. (as far as i understand the process)
do i need to create a feature service first or perhaps create a feature service attribute within my portal upload?
hopefully that makes sense.
cheers
jiriteach
Participant
  • Participant
  • Apr 15, 2019 7:07 PM UTC
Hi - Is your intention to post yo Portal to create a feature service or just upload the item for storage? If it’s to create a feature service then use an ArcGIS Online or ArcGIS Enterprise (Portal) writer.
This takes care of the service creation for you if it’s not already in place. The service is created based on the input structure.
