Not being able to use the AutodeskBIM360DocsConnector transformer
  • May 1, 2023 5:29 PM UTC
  • 60 views
arthy
Forum|alt.badge.img+8
I'm not able to use the the transformer AutodeskBIM360DocsConnector anymore.
It keep showing a 400-Invalid redirect_uir error message.
How could I solve this issue?
  • May 1, 2023 5:54 PM UTC
You'll probably have to verify that the redirect URI specified in the web connection is exactly the same as the one specified in the Autodesk BIM360/ACC console.
arthy
  • May 1, 2023 6:07 PM UTC
Thanks @david_r​
I'm getting this error when trying to add a web connection.
Normally, I clicked on add web connection, then on authenticate and I'm supposed to be redirected on a signing page for Autocad Cloud Construction instead of an error message.
I haven't entered anything on the list options parameters so I don't know where to verify redirect URI that you are referring to.
  • May 2, 2023 7:06 AM UTC
Thanks @david_r​
You'll need to look at the web service configuration, not the connection. In FME Workbench, look under:
Tools / FME Options / Web connections / Manage services
See also https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Desktop/!NamedConnections/options_web_service_connections.htm#Viewing,
