Microstation V8 Writer offsets text
  • Apr 9, 2025 1:49 PM UTC
  • 70 views
lgrie
Forum|alt.badge.img+8
Hello,
I am facing problems with my Bentley V8 Writer :
The Writer offsets my text (labels) and I don’t know why. I just upgraded the Writer from 2022 to 2024.
In the earlier version (2022) I didnt have this kind of problem.
As I am not very familiar to Microstation I ask you to share your idea. :)
Thanks in advance !
In the attachements you’ll find an image showing the error and a an exemple for tests.
kailinatsafe
Forum|alt.badge.img+24
Hello ​@lgrie, thanks for posting! To get a better idea of what is going on, are you able to shed light on the following:
  • Can you confirm the FME Form version/build in use? (Help > About FME Workbench)
  • What type and size of font is applied in your DGNv8 file?
  • Are you noticing the offsets in the FME Form’s Visual Preview Window / Data Inspector application, or only after opening them in MicroStation? (or in all applications?)
  • Are you able to share a sample DGNv8 file?
If you are unable to share a sample dataset publicly, please consider submitting a support case with us! Happy to help, Kailin.
