MaximoSaasObject Updater
  • Oct 10, 2023 7:10 PM UTC
  • 13 views
gboquin
Forum|alt.badge.img+8
Hi @daveatsafe​! I am trying to use the Maximo object updater but I am missing the existing object url. Per the documentation I can use the Object Querier the problem is that I cant seem to figure out which attribute to use as there are several url lake attributes. Any thoughts/ guidance that you can provide would be amazing.
Thanks so much in advanced.
G
daveatsafe
Forum|alt.badge.img+24
  • Oct 10, 2023 7:33 PM UTC
Hi @Gerardo Boquin​,
The 'href' attribute from the MaximoObjectQuerier will give you the existing object url.
