Link parameters
  • Aug 4, 2022 9:28 AM UTC
  • 129 views
user01
Hello !
I use a SystemCaller in order to copy files.
This files come from 2 differents folders and have to be copied from to different ways (command lines are differents) and - in addition- I want the user to choose if he wants to "copy/Y" or "Ycopy" the files.
So I have 2 types of command lines from 2 publics parameters but they have the same values "Copie SANS sous-dossiers" and "Copie AVEC sous dossiers":
imageAnd
image.pngSo when the user run the workbench he has 2 parameters to choose but they are named the same way:
imageIt is possible to link these 2 parameters and give the user only one parameter to choose ?
Thank you !
Best answer by dustin
Actually, the values are different :
You will need to use a Conditional Value in each of your AttributeCreators. If the parameter = Copie AVEC sous dossiers, then do this. If parameter = Copie SANS sous dossiers, then do that.
dustin
Forum|alt.badge.img+36
  • Aug 4, 2022 10:53 AM UTC
In your AttributeCreators, point them both to a single parameter since they both have the exact same value. Then simply delete the one not being used.
user01
  • Aug 4, 2022 1:40 PM UTC
dustin
  • Aug 4, 2022 1:49 PM UTC
user01
  • Aug 5, 2022 8:20 AM UTC
yes, logical ! It works. Thank you !
