limitation of use with dataInterop
  • Jan 6, 2020 8:15 AM UTC
  • 63 views
Hi, Happy New year 2020 !!!
on a customer's site, equiped with DataInterop in two different configurations :
  • FME 2018 inside ArcMap
  • FME 2019 inside ArcGIS Entrerprise,
we encountered two problems :
  • JPEG2000 format is not supported in reader/writer
  • and when we try to write a PDF geospatial (2D) , FME blocks with a message indicating that JPEG2000 is requested for the operation ... even if the image source (reader) is GeoTIFF ....
is it normal ? is it a restriction of DataInterop ?
regards,
bruceharold
Forum|alt.badge.img+19
  • Jan 6, 2020 2:33 PM UTC
Pascal, Data Interoperability extension does not support JPEG2000. GeoPDF should work fine, please log a support call with Esri and share a sample file.
Thanx Bruce !!
