LAUTEC with FME
  • Oct 15, 2026 6:37 AM UTC
  • 27 views
jyorhd
Participant
Has anyone connected LAUTEC DPR via FME to fetch daily data of vessel?
nickcumming
Forum|alt.badge.img+14
Hi jyorhd,
This is interesting!
I believe LAUTEC DPR has an API, but I cant seem to find any documentation. If they do have an API, the HTTPCaller is the place to start: call the endpoint with your API token, then use the JSONFragmenter to turn the response into features.
If an API isn’t available, a few other routes could work:
  • CSV/Excel export: read it straight into FME Form with the CSV or Excel reader.
  • PDF export: DPR reports follow a fixed template, so text and tables can be pulled out with a PythonCaller (e.g. pdfplumber) or the StringSearcher.
  • Automating it daily: if the reports can be emailed, an FME Flow Automation with an Email trigger can save the attachment and pass it to your workspace each time a new report arrives. A Directory Watch trigger does the same for files exported to a shared folder.
Let us know how you get on. If anyone else has connected LAUTEC DPR to FME, we’d love to hear how you did it!
