Is there any possibility to change the database view for fme when integrate with smallworld ?
  • Apr 25, 2022 7:26 AM UTC
  • 49 views
I am getting some records from replicate view in smallworld and fme unable to read these value bcoz fme is working on the current view in smallworld.
IS there any possibility to change the current view to replicate view of smallworld in fme
kailinatsafe
Forum|alt.badge.img+24
Hello @alapatisriranga​ , can I ask what you mean by 'replicate view'? Best, Kailin
Actually I am integrating fme with smallworld. In smallworld there is replicate view which is the duplicate database view of the original.
kailinatsafe
Hello @alapatisriranga​ , thanks for clearing that up. If you’ve already established your FME and Smallworld integration (eg. you’re able to read the ‘current’ view), I think you can create a new database connection for your ‘replica’ view and change the Server port parameter to have it read the ‘replica’ view (likely different port number). The Smallworld training series describes how to connect to a Smallworld database, here (Connecting to Smallworld Tutorial). If this did not address your question, please let me know! Best, Kailin.
Hello @kailinatsafe​ , I will try with this process once and check whether it is working or not.
Thanks, Sriranga.
