Instead of adding a shutdown python script, is it possible to call a python script when the translation has completed?
  • September 29, 2017
  • 7 replies
  • 12 views
I have developed some python scripts to be run when translations are completed. I developed these in PythonWin. I've been pasting the text of these scripts into the "Shutdown Python Script" area under Workspace parameters. Can I call the scripts instead?
Best answer by takashi
Hi @angela, if you are looking for a way to run a script defined in an external Python script file when the translation has completed, an easy way is to save your script file (*.py) into the same directory in which you have saved the workspace file (*.fmw), and import it as an module in the shutdown script.
For example, if you have "my_script.py" that contains a function called "my_func()", you can call the function in the shutdown script like this.
import my_script
my_script.my_func()
See here to learn more: Python Documentation > The Python Tutorial > 6. Modules
You can also use a function or class defined in an external file with a PythonCaller.
 However, note that the function/class definition has to be conformed to the templates described in the transformer parameter "Python Script". For example, a function that you want to call with a PythonCaller should take a single argument which stores an fmeobject.FMEFeature object.
# my_script.py
def my_func(feature):
    # do something
    pass
PythonCaller parameters:
  • Python Script: import my_script
  • Class or Function to Process Features: my_script.my_func
Hope this helps.
davideagle
Forum|alt.badge.img+21
How about swapping from using a writer to using a FeatureWriter transformer instead, that means you can now write out the data and then have a PythonCaller immediately after the FeatureWriter to initiate your script. That should avoid the need for the shutdown script.
Thanks. I'll look into that. So far I'm not seeing anywhere in PythonCaller to enter the path to the script I want run. Maybe it's not that simple.
danilo_fme
Forum|alt.badge.img+42
Hi @angela,
According the good tip that @1spatialdave wrote, the transformer PythonCaller can it use .
About the how use the PythonCaller has a serie interesting Link:
1) PythonCaller User Parameters
2) Python and FME Basics
Thanks,
Danilo
  • September 30, 2017
import my_script
my_script.my_func()
# my_script.py
    # do something
    pass
Hope this helps.
  • October 1, 2017
import my_script
my_script.my_func()
# my_script.py
    # do something
    pass
Hope this helps.
Besides, if you want to use an external script file (*.py) saved under a specific directory in the system, you can add the directory path to the sys.path list and then import the file. For example, if 'my_script.py' is saved in 'C:/scripts' directory, it can be imported with this codes.
import sys
sys.path.append('C:/scripts')
import my_script
  • October 2, 2017
import my_script
my_script.my_func()
# my_script.py
    # do something
    pass
Hope this helps.
Very helpful, thanks.
Hi @angela
you can use SystemCaller instead of the PythonCaller and run a command similar to:
C:\Python27\python.exe C:\Users\Username\Desktop\my_python_script.py
