If file1 exists send to dir A else if file2 exists send to dir B, etc
  • Nov 25, 2019 10:45 PM UTC
  • 152 views
kieranmg
Forum|alt.badge.img+3
Hi All,
Based on a folder name i want to move files from A to B in FME
So for example:
- zip file is received via httpCaller and saved to a default location
- within that downloaded zip file, i want to extract one folder & its contents (probably using systemCaller)
- The internal folder will have 1 of 5 possible names(lets say finance, sales, IT, etc)
- Its destination will depend on the the folder name
I dont think theres a transformer for this, to check if a file exists?
So i'm guessing it would be a python script of sorts to check if each of the file names exist, set an attribute based off of that result, then filter. but im useless at python, its on my 'to learn' list. Any help is appreciated!
Best answer by jdh
There's a custom transformer on the hub called FileExistenceChecker
jdh
Forum|alt.badge.img+41
  • Nov 25, 2019 11:08 PM UTC
kieranmg
  • Nov 26, 2019 9:31 PM UTC
thank you!
kieranmg
  • Nov 27, 2019 4:44 AM UTC
Just to add things i've noticed with FileExistenceChecker so far:
- Its case Sensitive
- You need the file extension
- It will check if a folder exists but you need the backslash at the end, e.g. \\\\server\\folder\\
