I am getting the error below while trying to load data into a feature service with branch version using FME, anyone who can help me resolve this? Willing to provide more info when requested. Thank you.
  • Jun 27, 2023 2:36 PM UTC
  • 195 views
ArcGIS Portal Feature Service Writer: Writer configured to use Global IDs, but this is not supported by the Feature Service
ARCGISPORTALFEATURES writer: A fatal error has occurred. Check the logfile above for details
FeatureJoiner_3 (FeatureJoinerFactory): A fatal error has occurred. Check the logfile above for details
FeatureJoiner_3 (FeatureJoinerFactory): ARCGISPORTALFEATURES writer: A fatal error has occurred. Check the logfile above for details
trentatsafe
Forum|alt.badge.img+7
HI @jmuriithi​
Can you confirm if your Feature Service has GlobalIDs enabled on it? This can be found via the Service definition page of the Feature Service(it should look like JSON). As Branch Versioned Feature classes/services must have GlobalIDs
  • Jun 29, 2023 7:32 AM UTC
Hi thank you for your response, indeed I confirm all the layers in the feature service have Global IDs. The service itself has this as false though: Supports ApplyEdits With Global Ids: false
