HTTP transfer error: SSL connect error
  • Oct 24, 2024 12:34 PM UTC
  • 7 replies
  • 550 views
dannykgf
Hi all,
I had build a workspace in FME dekstop using httpcaller to get data from an api and its working. When i publish this on the server, then i get the following errors.
HTTPCaller (HTTPFactory): [1]: HTTP transfer error: SSL connect error
HTTPCaller (HTTPFactory): [1]: Please ensure that your network connection is properly set up
HTTPCaller (HTTPFactory): [1]: No proxy settings have been entered. If you require a proxy to access external URLs, please ensure the appropriate information has been entered
I have already check on the server and i can reach the api by web.
Does anyone what the issue is?
kind regards,
hkingsbury
Forum|alt.badge.img+73
  • Oct 24, 2024 9:05 PM UTC
In the HTTPCaller you can disable verifying SSL Certificates. If you disable that, does the call work?
dannykgf
  • Oct 25, 2024 2:05 PM UTC
Hi @hkingsbury  i already disable the verifying SSL certificates, and still received the same issue.
ali-safe
Forum|alt.badge.img+24
  • Oct 28, 2024 7:04 PM UTC
Hi, @dannykgf!
Thanks for posting your question! If your comfortable, could you share a few details about your setup? If not totally fine! Can open up a support ticket with us and we can take a look from there.
Which OS you are using? Is it a Virtual Machine? Do you have a proxy setup? Which version of FME Desktop/Form are you running?
We’ve seen one case with Windows Server 2016, it can cause this sort of error due to the OS ciphers. Happy to help!
Thanks!
dannykgf
  • Oct 30, 2024 10:12 AM UTC
Hi @AliAtSafe ,
Thank you for your response. I just contact the department and they told me the following:
  • OS is still now on a Windows Server 2012 for some reason, but its in the planning for upgrade. Its on a Virtual Machine
  • FME Server version is 2022.2.2
  • FME Desktop version is 2022.2
  • There is no proxy setup
From the Server you can access the API by web.
I can also execute the workspace in desktop version  with succes but when i publish it on the server, it doesnt work.
Thanks in advance,
ali-safe
  • Oct 30, 2024 4:01 PM UTC
Hi, @dannykgf.
Thanks for your response and providing those details, appreciate it! To best pinpoint what may be causing this, if you could create a ticket with us and share the same details with your workspace and logs from Desktop and Server, we can take a closer look. Could you also  provide the link to this question thread in the ticket too?
Thank you!
rakeshent
Forum|alt.badge.img+3
  • Feb 9, 2026 10:09 PM UTC
Hi ​@dannykgf
Did you get a solution from support team? I know a python way but wanted to use FME transformers to keep it simple.
ali-safe
  • Feb 9, 2026 10:41 PM UTC
Hello ​@rakeshent.
I believe ​@dannykgf found a workaround from this past community post - I would try to follow along with it. Let me know how that goes.
Best,
