How to use HTTPCaller to upload a file?
  • Jan 9, 2023 9:59 PM UTC
  • 307 views
brandonguo
Forum|alt.badge.img+7
New to the API world. I am trying to use HTTPCaller to auto-attach a pdf file as a response.
I managed to use HTTPCaller to get all requests and auto-generate a response. However, I am unsure how to physically upload the file through the POST method.
Here is the link to the API document: Enquiries API (1100.com.au)
My HTTPCaller parameters:
imageI keep getting: "HTTPCaller_4 (HTTPFactory): [1]: HTTP transfer error: Stream error in the HTTP/2 framing layer" error code.
f.kemminje
Forum|alt.badge.img+11
  • Jan 10, 2023 3:58 AM UTC
Have you ever used Postman app or web application? whether it was successful or not
Debug with Telerik Fiddler. you will get The precise url string to upload the files.
brandonguo
  • Jan 10, 2023 9:56 PM UTC
No, I haven't, I will give it a try. I think I get confused with the "Files" array and the actual reply I want to upload. After converting pdf to HTML code and packaging it into JSON, all works. Thank you.
