How to get the SharePoint Online connector working (again)?
  • May 31, 2023 1:16 PM UTC
  • 0 replies
  • 129 views
speknl
Hi there,
Until a few days ago we had a working SharePointOnline Connector in FME which uploaded a .dwg file every day. After updating to FME Workbench 2022.2 that stopped working. A saw in the webservices options that the Tenant-ID was replaced with the string 'common' so I reverted this to our setttings. I used this YouTube-video for implementing the right settings inside FME.
I can test the webconnection which is succesfull. But encounter a number of error messages. See below.
I've also been troubleshooting together with IT to make sure that all proxy/FireWall settings are correct but nothing has changed there.
Thusfar I've encountered the following error-messages:
As of now FME also stopped opening the webservices settings menu. It just shows the blue windows loading circle.
Hopefully some of you recognize these errors and point me in the right direction for a solution.
Thanks in advance!
best regards,
Jaap
