How can i select specific engine for the job using REST API?
  • Feb 1, 2017 4:07 PM UTC
  • 78 views
Best answer by itay
Hi @kofizzz,
You can specify the engine tag via the API by using the TMDirectives as described by the API documentation.
Hope this helps.
itay
Forum|alt.badge.img+19
  • Feb 1, 2017 7:08 PM UTC
Hi @kofizzz,
Hope this helps.
fmelizard
Forum|alt.badge.img+22
  • Feb 1, 2017 7:20 PM UTC
Hi @kofizzz,
Hope this helps.
The 2017.0 doc experience is a bit better:
https://docs.safe.com/fme/2017.0/html/FME_Server_Documentation/Content/AdminGuide/Configure_Job_Routing.htm?Highlight=tag
It works the same in 2016.
