Help with connecting to Microsoft Dynamics 365
  • May 18, 2026 7:05 PM UTC
  • 57 views
mnash
Following the instructions: How to Connect to Microsoft Dataverse using FME Form – FME Support Center
I can successfully authenticate to Dynamics 365. However, when I create a Reader and attempt to List the available tables, I get HTTPError: 404.
The error message suggests the URL is being incorrectly formed by including “/user_impersonation offline_access/”
<domain> is redacted real address….
Error URL:
https://<domain>.crm6.dynamics.com/user_impersonation offline_access/api/data/v9.2/EntityDefinitions?$select=LogicalName,EntitySetName,DisplayName,PrimaryIdAttribute&$filter=IsValidForAdvancedFind+eq+true
Expected URL:
https://<domain>.crm6.dynamics.com/api/data/v9.2/EntityDefinitions?$select=LogicalName,EntitySetName,DisplayName,PrimaryIdAttribute&$filter=IsValidForAdvancedFind+eq+true
All assistance gratefully received….
j.botterill
Forum|alt.badge.img+69
  • May 19, 2026 4:40 AM UTC
error 404 speaks to an incorrect API url/endpoint. You can try updating the reader, take a look is a newer version is in the transaction log and try again. Otherwise I think you should reach out to Safe Support and lodge a request
mnash
  • May 20, 2026 11:35 PM UTC
Thanks. I have logged a Support ticket and waiting for response.
