getting an Oauth signature
  • Mar 9, 2017 8:49 PM UTC
  • 8 replies
  • 82 views
johnglick
Forum|alt.badge.img+7
hi, i'm attempting to connect a workspace to a generic api that uses Oauth 1.0a. the service requires a unique Oauth signature for each type of request. I can get a signature using their test app, but my problem is that i need to download an array of files using the FME workspace and I need a signature for each file request. Any ideas how that could be accomplished?
itay
Forum|alt.badge.img+19
  • Mar 9, 2017 9:35 PM UTC
can you provide the link to the service?
johnglick
  • Mar 9, 2017 10:04 PM UTC
sure the documentation can be found at developer.deere.com
itay
  • Mar 10, 2017 7:14 AM UTC
Which end point are you trying?
johnglick
  • Mar 10, 2017 12:30 PM UTC
itay
  • Mar 10, 2017 1:23 PM UTC
johnglick
  • Mar 10, 2017 1:25 PM UTC
I'm using the myjohndeere api.
itay
  • Mar 10, 2017 4:29 PM UTC
Have you had a look at the adding the oauth as a web connection via the tools menu >fme options>web connections ?
usually Safe advises to contact them if assistance is needed for these matters you can do that via support.
johnglick
  • Mar 10, 2017 7:40 PM UTC
yes, I've tried that, it made no difference. I will contact support.
