FTPCaller- Error in the SSH Layer
  • Jun 13, 2019 5:46 PM UTC
  • 158 views
I'm using the FTP Caller Transformer to download a file geodatabase from an sFTP site. I feel like I've tweaked every possible parameter. My data keeps ending up rejected with an "Error in the SSH Layer."
Any ideas?
mferwerda1111
Participant
If you have not, you might try turning on log debug under options, that sometimes provide a more detailed error
  • Jan 17, 2024 1:33 PM UTC
Did you check the path of the file/folder ?
If you want to list the content of a folder, the path should end with a slash otherwise it will throw you error.
