FME Server Web Interface Errors [MissingResourceException]
  • Mar 4, 2014 11:34 AM UTC
  • 53 views
martinhorvath
Participant
Hi@all,
I am having major troubles with FME Server 2013. Everything installed fine on our dev-servers, but on production, I am facing the fact that FME is running, accepts connections from workbenches etc. but it is NOT showing the login boxes etc. in the web-interface. In Tomcat, I can see many of the following logs... anyone of you has an idea how to fix this?
Regards,
Martin
Mar 4, 2014 2:23:40 PM org.apache.catalina.core.StandardContext loadOnStartup
SEVERE: Servlet /fmerest threw load() exception
java.util.MissingResourceException: Can't find bundle for base name clients.fmerest.fmerest, locale en_US
at java.util.ResourceBundle.throwMissingResourceException(Unknown Source)
at java.util.ResourceBundle.getBundleImpl(Unknown Source)
at java.util.ResourceBundle.getBundle(Unknown Source)
at COM.safe.utility.i18n.FMEPropertyResourceBundle.init(FMEPropertyResourceBundle.java:45)
at COM.safe.utility.i18n.FMEResourceManager.getResourceBundle(FMEResourceManager.java:65)
at COM.safe.utility.i18n.FMEResourceManager.getResourceBundle(FMEResourceManager.java:56)
at COM.safe.webservices.utility.WebServiceResourceHelper.init(WebServiceResourceHelper.java:56)
at COM.safe.webservices.fmerest.library.request.NewRESTServlet.init(NewRESTServlet.java:119)
at javax.servlet.GenericServlet.init(GenericServlet.java:160)
at org.apache.catalina.core.StandardWrapper.initServlet(StandardWrapper.java:1266)
at org.apache.catalina.core.StandardWrapper.loadServlet(StandardWrapper.java:1185)
at org.apache.catalina.core.StandardWrapper.load(StandardWrapper.java:1080)
at org.apache.catalina.core.StandardContext.loadOnStartup(StandardContext.java:5015)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5302)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:897)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:873)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:615)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:958)
at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1599)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Mar 4, 2014 2:23:41 PM org.apache.catalina.core.StandardContext loadOnStartup
Mar 4, 2014 2:23:47 PM org.apache.catalina.core.StandardWrapperValve invoke
SEVERE: Servlet.service() for servlet [BundleREST] in context with path [/fmeserver] threw exception
java.util.MissingResourceException: Can't find bundle for base name clients.fmeweb.home, locale en_US
at COM.safe.fmeserver.webui.BundleHelper.loadBundle(BundleHelper.java:38)
at COM.safe.fmeserver.webui.servlet.rest.BundleREST.doGet(BundleREST.java:31)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:621)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:722)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
at COM.safe.web.servlet.CharsetEncodingFilter.doFilter(CharsetEncodingFilter.java:538)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:224)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:169)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:168)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:927)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:407)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:987)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:579)
at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.run(AprEndpoint.java:1805)
kathyross
Participant
Forum|alt.badge.img+9
  • Participant
  • Mar 7, 2014 3:34 AM UTC
A reinstall may be the way to go. If the log files are complaining about missing bundles and the install worked fine on another machine, back up everything and try again.
Lack of permissions or upgrading from an earlier version can cause an install to be incomplete and have errors like this.
