FME Server REST API: Where can I find a comprehensive documentation on parameter values applicable to a publication?
I'm planning to develop a system that should contain a function to automatically configure a publication on an FME Server according to parameters set by a user via a web app.
I think it should be possible with FME Server REST API [POST] /notifications/publications (Create Publication).
However, so far, I've not found a comprehensive documentation on parameter values such as "publisherName", "properties/name" etc. applicable to a publication - e.g. Email (SMTP) publication.
Where can I find that?
itay
Forum|alt.badge.img+17
  • January 6, 2019
I am afraid that the swagger API documentation is the most extensive documentation available that I know of, hopefully a Safe employee can shed some more light on this matter.
  • January 7, 2019
I wonder if it's possible to use something like Fiddler to intercept and reverse engineer the API calls used by the GUI?
  • January 7, 2019
Good idea. I'll give it a try later! Thanks.
Hi @takashi
There is also an example using the FME Server JS API, which dynamically exposes all parameters for all available protocols:
https://playground.fmeserver.com/javascript/notifications/create-publication/
Maybe this helps as well.
