FME Server License JSON FILE request has very slow response
  • Apr 25, 2019 3:43 PM UTC
  • 52 views
adieporter
Hi all
Just wondering if Has anyone has experienced very slow request times when downloading the licensing JSON request file?
We have a new install of FME Server 2018.1 on linux RHEL7. Its offline so we must download the license request JSON file. We requested via the web-ui and it took nearly 10 minutes to return the file. We tested using the REST API test page with similar timings. Other REST calls seems to work fine.
We've done a number of installs the mirror this onto different environments with out encountering and delay.
The logs do not seems to indicate anything adverse.
A bit of a head scratcher but thought I'd see if the hive mind could help.
Cheers
Adie
  • Apr 25, 2019 3:45 PM UTC
Yes, I can confirm that it's always been super slow for me as well. I have no idea why...
adieporter
  • Apr 25, 2019 3:56 PM UTC
Thanks David
Good to know its not just me.
Its doing what it needs to just super slow, We have three other environments all seemed fine.
Hopefully not a sign of other issues
Cheers
Adie
