FME Server : FTP trigger with FTPES does not work
  • Feb 3, 2020 4:03 PM UTC
  • 136 views
I'm using the FTP trigger in FME server with a FTPES site but it doesn't work. It does work in a FTPCaller Transformer.
the logs in FME UI are not very useful (the logs here are shown in reversed timestamps):
In the logs here : tail -f /opt/fmeserver/resources/logs/core/current/publishers/ftpwatch.log
there are some clues but I can't figure out why this is happening on server and not in the transformer :
it.sauronsoftware.ftp4j.FTPException [code=503, message= SECURITY_FTPES cannot be applied: the server refused both AUTH TLS and AUTH SSL commands]
at it.sauronsoftware.ftp4j.FTPClient.login(FTPClient.java:1229)
at it.sauronsoftware.ftp4j.FTPClient.login(FTPClient.java:1186)
at COM.safe.fmeserver.relay.plugin.ftpwatch.FTPWatchPollingThread.loginToFTPServer(FTPWatchPollingThread.java:454)
at COM.safe.fmeserver.relay.plugin.ftpwatch.FTPWatchPollingThread.poll(FTPWatchPollingThread.java:139)
at COM.safe.fmeserver.relay.plugin.ftpwatch.FTPWatchPollingThread.run(FTPWatchPollingThread.java:111)
The ftpcaller with parameters "binary / passive / Verify SSL / Password" work with the same site.
Does anyone already experienced this kind of issue ?
Is there any way to add parameters or control the FTPWatcher in FME Server ?
EDIT :
the ftp_watch works with subscriptions but not within automation. I'm puzzled :/
Versions :
FME Server 2019.2 / Build 19735 - linux-x64
Thanks for your help or advices !
nampreetatsafe
Forum|alt.badge.img+14
Hi @egenestine! Thanks for the details. Looks like build 19735 was a Beta build. Would you mind giving it a shot with an official release and let us know if you have any luck with that?
According to @lauraatsafe here https://knowledge.safe.com/answers/96246/view.html, the FTP Watch should work with FTPES within Automations.
We're curious to hear if you have any luck with an official release.
  • Mar 4, 2020 9:20 AM UTC
I've upgraded FME server but with no luck. It works fine with triggers but I think it's a tricky solution for someone without strong technical knowledge and I definitely prefer using automation for this kind of process as I won't be the end user.
Is there any parameter that switch on more details in the logs ?
what kind of useful information should I enable/trace that would help me and lead to a solution ?
Thanks,
Eric
_fabian_
Forum|alt.badge.img+5
  • Feb 18, 2025 11:27 AM UTC
The Issue still persists in FME Flow 2024.2.3. I suspect that the FTPS Server (Bitvise SSH) sends the message “234 Security mechanism set to TLS” but the ftp4j plugin used in FME Flow only expects a number in the response (see the readFTPReply function), or FME Flow just handles the resposne incorrectly.
Any chance this will get fixed?
siennaatsafe
Forum|alt.badge.img+12
Hi ​@_fabian_ ,
I'm sorry you're encountering this issue. I haven't come across any other reports in our current build, so it looks like we’ll need to file a new ticket for our development team to investigate and resolve this.
Could you please file a support case so we can follow up with you directly? Your help in providing more details will be much appreciated.
Thank you for your patience
