FME Form - MCP Server - Claude AI
  • Apr 15, 2026 8:26 AM UTC
  • 499 views
gimmy15+
Forum|alt.badge.img+7
I developed a small MCP server that exposes an FME workbench (.fmw) as a service that can be invoked via natural language, using an AI client (e.g., Claude).
The interesting aspect is the architecture and the simplicity of "assembling" the various components:
1) I build the FME flow that executes the workflow, managing logic, transformations, and formats (we leave to FME what belongs to FME),
2) the MCP server exposes operations and parameters in a controlled manner,
3) the AI ​​client interprets the request in natural language and translates it into a structured call.
hkingsbury
Forum|alt.badge.img+73
  • Apr 16, 2026 12:52 AM UTC
Thats really cool!
I haven’t really been keeping up much of the developments in FME in this space. If I understand what you’re doing correctly, you’re able to ask Claude (using natural language) to use FME to convert a tif to las?
The MCP component of FME Flow is shared with Claude so it know what operations/functions can be performed by it? It then goes off and triggers a job and returns the result
gimmy15+
  • Apr 16, 2026 6:58 AM UTC
I developed this simple interaction tool between FME Form and Claude AI shortly before Safe's presentation on FME Flow's MCP tools.
Your interpretation, however, is correct: I asked Claude (using natural language) to use FME to convert a TIF file to LAS.
The fmw workbench that performs the conversion is made available to a local MCP server that Claude can access.
jhu_20
Forum|alt.badge.img+12
  • Jun 1, 2026 7:27 PM UTC
Once you have a FME Flow MCP,  how do you interact this MCP from claude ?   I like to get more info on the detailed steps.   Thanks.
gimmy15+
  • Jun 3, 2026 7:22 AM UTC
the MCP server I developed exposes a workbench on my local machine: I used Claude (natural language invocation), a local MCP server (Claude <==> FME FORM) and FME FORM on my machine.
As i said before: I developed this simple interaction tool between FME Form and Claude AI shortly before Safe's presentation on FME Flow's MCP tools. That’s why I run it on my local machine using FME FORM.
The MCP server is a simple python script that uses fastmcp (https://gofastmcp.com/getting-started/welcome) to pass parameters from my natural language invocation in Claude in my .FMW workbench.
I hope it’s helpful.
