FME desktop SOAP service issue problem
  • Jan 11, 2019 3:03 PM UTC
  • 50 views
hı,
I'm trying to get SOAP services with FME. I've connected to some soap services using the following example.
https://knowledge.safe.com/articles/45314/working-with-soap-services.html
The soap service I'm trying to connect to now has IP-based authorization. and it requires authentication.
I can connect with SoapUI.
the result window of the request is as follows.
XMLtemplater image ==>
HTTPCaller image ==>
error output ==> HTTPCaller(HTTPFactory): Received HTTP response header: 'HTTP/1.1 500 Internal Server Error'
where the problem comes from. can you help please
thanks..
  • Jan 11, 2019 3:33 PM UTC
It's a bit hard to tell from the screenshots, but is it possible that you've forgotten to include the SOAPAction header? SoapUI applies this automatically (you can see it in the RAW-tab of the request, however), where as in FME you'll have to specify it manually, e.g.
