FME AR - Add attributes
  • Apr 16, 2019 1:56 PM UTC
  • 88 views
Good morning,
I am working with FME AR, and I would like to add attributes to some line work. Is it possible to do that?
My idea is I would like to be able to select a line in AR and it would display attributes about the line.
Thanks!
David
Best answer by chrisatsafe
Hi @david_prosack88,
Unfortunately, this is not possible with FME AR Writer at the moment as the FME AR writer is currently based on the OBJ format which does not support attributes. However, this would be a great feature to have in the future - there was also a suggestion for this functionality in the Augmented Reality, Spatial Data, and 3D Models: Making your own AR models using FME’s “fmear” format blog post in the Future Updates for FME and Augmented Reality section!
It might be worthwhile to suggest this on the Ideas Page with a use case as well!
chrisatsafe
  • Apr 17, 2019 5:41 PM UTC
danilo_fme
Forum|alt.badge.img+58
  • Apr 17, 2019 6:20 PM UTC
Hi @chrisatsafe
Thanks for endorsing this doubt. It was very insteresting !
danilo_fme
  • Apr 17, 2019 6:21 PM UTC
A interesting Idea it!
Thanks @chrisatsafe for the response! I have added this to the idea page.
David
