Esri portal Feature Service Upsert
  • Oct 25, 2024 9:36 AM UTC
  • 211 views
meijer
Forum|alt.badge.img+3
Hi all,
I’m working with a Feature Service containing approximately 1,000,000 sensors stored in a spatiotemporal big data store. I need to update 10,000 of these sensors based on their unique string ID, like sensors-0x21222.
Currently, I'm using the FeatureWriter for the 'Esri ArcGIS Portal Feature Service' with the 'Use Global IDs' option enabled and 'Upsert' set as the 'Feature Operation' in the Feature Type. However, 'Upsert' requires a global ID.
This approach feels very constrained, as it requires importing all 1 million records, merging them, and finding the global ID for each update.
Is there a way to update a Feature Service using a primary key or unique field (such as upserting with a where clause) rather than relying on global IDs? This current method doesn’t seem ETL-friendly, as it requires importing parts of the dataset just to make updates.
Thanks in advance for any guidance!
Edit:
Maybe I don't understand it. But for every featureservice/layer/featuretype I need to add, to first fetch the globalids before I can do in upsert/update
If you need to update lets say 10 featureservices and big numbers of features it just feels wrong.​​​​​​
nielsgerrits
Forum|alt.badge.img+67
Not sure if I understand correctly. If you want to only update 10.000 of 1.000.000 records, why don’t you use update instead? You can then limit what you need to read by a where clause.
meijer
  • Oct 25, 2024 1:01 PM UTC
If you want to update, you also need an objectid. The data that I am reading has no globab/object-id's. It has a string-key that is the primary key.
I don't want to import any data into FME just to write it in a database. That would increase memory and time.
Maybe this explains my issue:
For all features I need to process thought this, to receive a globalid and upsert. (or update)
This example as a subselection of data so it has low number of features.
bruceharold
Forum|alt.badge.img+19
  • Dec 6, 2024 1:44 PM UTC
I think provided your key field has a unique constraint you can use it as the upsert key, you can add the constraint via the item fields page in your portal.
