Escalate different folders to load just certain data
  • May 27, 2016 9:54 AM UTC
  • 59 views
  • May 27, 2016 11:32 AM UTC
Hi
I'm not quite sure what you mean by "escalate" in this context, but if you need to read the contents of a folder structure, there is the "Directory and File Pathnames" reader which will return one feature for each file found, according to your criteria. You could then send the filename to a FeatureReader (or a WorkspaceRunner calling a second workspace) for further processing.
David
  • May 27, 2016 1:37 PM UTC
Look under the menu Readers / Add Reader...
