Elevation Service ArcPy
  • Apr 3, 2024 6:27 PM UTC
  • 54 views
sharmankita2314
Participant
Hi,I am trying to publish a elevation mosaic dataset as a elevation layer to portal but it is rendering as imagery layer. The sd draft created in the script does not allow me to set Lerc as compression and the default is PNG8.Can anybody help with ArcPy publishing for elevation services ?
danminneyatsaf
Forum|alt.badge.img+13
Hi @sharmankita2314, how are you using FME Desktop/Form for these workflows? Are you running the ArcPy code through a PythonCaller?
If you have a workspace you’re able to share with us that’d be great.
