Deleting File from Destination Directory
  • Apr 8, 2020 5:59 PM UTC
  • 209 views
I have a requirment to delete a file if the workspace has failed and I need to revert the output file which I have written. I used python caller to remove by passing a file path as parameter, but the file is not removed from the directory, however the translation is showing as successful with 0 features written.
  • Apr 8, 2020 6:17 PM UTC
Hi @rajkumarf3
A quick look at the python caller and your filepath variable does not refer to any attribute
file_path = feature.getAttribute('')
This needs to be
file_path = feature.getAttribute('file_path')
Just checking that you are running this with a workbench runner as remember if a workspace fails then nothing else get run.
Cheers Dave
