database connections with password over 245 characters are not working
  • Mar 12, 2026 11:45 AM UTC
  • 109 views
b.hollebeek
Forum|alt.badge.img+3
I need to use a Oauth2 token as password to connect to a PostgreSQL database. The problem is that when I try to paste a stringline over 245 characters the connection fails. When reopening the connection parameters the password is red and says ‘Value not allowed’. On another laptop (FME 2022.2) it all works fine. Any idea what causes this problem?
Best answer by jamatsafe
Hi ​@b.hollebeek, thank you for reaching out and reporting this. This issue was previously tracked under FMEFORM-32268 internally and a fix was released for 2024.2.1 onwards. The issue stems from a technical constraint in how unusually long strings were handled in the connection interface for that version, which has since been addressed in newer versions.
If upgrading is an option that would be the recommended path. Unfortunately, due to how the 2024.1 interface validates these strings, there isn't a direct workaround for that specific build other than using an alternative authentication method that uses shorter credentials. I hope this helps clarify things!
b.hollebeek
  • Mar 13, 2026 7:05 AM UTC
This problem is in 2024.1, not in 2022.2 or 2025.1
jamatsafe
Forum|alt.badge.img+25
  • Mar 13, 2026 11:36 PM UTC
