Connection To FME Hub in version 2021
  • Dec 17, 2024 9:16 AM UTC
  • 91 views
buttonsmc
Participant
Hi there,
Has anyone found a solution to FME Hub connection in Version 2021?
nielsgerrits
Forum|alt.badge.img+67
I have never used this functionality but I can reproduce this in 2021. If you really want to you probably can create a ticket at Safe, but I doubt they will fix it as 2021 is nearing end of support? There are alternatives:
  1. Click in the canvas and enter a term you are looking for. Like “tableau”. Click on the hub transformer to download and install.
  1. Go to https://hub.safe.com/browse and find the transformer you need, click on download and install manually by opening the .fmx
buttonsmc
Participant
  • Participant
  • Dec 17, 2024 11:55 AM UTC
Thank you so much for your reply ​@nielsgerrits, and for checking this out for me to demonstrate its not just a isolated issue. I have been using workarounds like you suggested but thought maybe there might have been a easy fix and as you suggest I would imagine logging the issue might not be worth it when this version is nearing end of support.
