Connecting to Cisco CMX
  • Apr 16, 2019 5:55 AM UTC
  • 62 views
magnus
Forum|alt.badge.img+7
Hi
I am trying to retrieve JSON location data from a CMX service. If I login using Chrome, I can access a JSON document from .../api/location/v2/clients and use that file as input in a workspace, but I would like to integrate the authentication process as well in the workspace. Any hints on how to achive this using the HTTPCaller?
The documentation can be found at https://www.cisco.com/c/en/us/td/docs/wireless/mse/10-2/api/b_cg_CMX_REST_API_Getting_Started_Guide/b_cg_CMX_REST_API_Getting_Started_Guide_chapter_01.html.
Magnus
magnus
  • Apr 16, 2019 9:08 AM UTC
Solved it, had to change the SSL option.
