Civil3d Multipatch - fixing attributes
  • Mar 21, 2024 3:15 AM UTC
  • 0 replies
  • 55 views
jd.fernandez
Participant
Good day,
Is there anyone here tried converting Civil3d Pipes and Structure into ESRI Geodatabase Multipatch in ArcGIS Pro?
My issue is the original attribute from Civil3d doesn’t copy in the converted Multipatch - when I convert using ‘CAD To Geodatabase’
Can FME translate Civil3d Pipe/Structure Property to change the incorrect Multipatch attributes?
Please see image below:
