Can we use FME for data migration from ArcFM Fiber to ArcFM enabled UNM?
  • Oct 20, 2022 6:21 AM UTC
  • 44 views
Can we use FME Desktop for data migration from ArcFM Fiber to ArcFM enabled UNM?
Are there any workbenches similar to Electric/GAS/WATER available for Fiber Telecom ?
@27poonamjagdale​ You should be able to use FME to move your data ArcFM Fiber to Utility Network model. We haven't developed any template workspaces for Telecom migration at this point, but the principals will be the same:
  • ensure your source data is squeaky clean by doing a thorough data quality audit
  • understand your UN data model and whether it is classed as Basic, Simple, Complex (hi-fidelity). This will help you understand what data might need to be created during the migration.
We'd be happy to discuss this further if you want - you can contact me directly at: mark at safe dot com
The Electric/Gas/Water migration templates mentioned and training mentioned above can be here.
