Can FME read/import an ArcGIS ImageServer
  • Mar 17, 2019 4:37 PM UTC
  • 359 views
bozboswell
Forum|alt.badge.img+7
With the help of this forum, I have been successful in reading an ArcGIS Feature Service using a token. I am trying now to simply read an REST ArcGIS ImageServer service. This is a raster of estimated rainfall over the past 7 days. I would like to read the service and derive the average rainfall within a buffered point. The issue is I cannot seem to connect to the image service to read the pixel values of the raster.
Any ideas?
nielsgerrits
Forum|alt.badge.img+67
Did you use the API and HTTPCaller to do this? Then simply look for Image Service in the REST API Documentation.
I think you need to do an Identify? (Hit a specific location and get the value returned.)
First check the Image Service if Identify is allowed.
Then use a HTTPCaller to make the request and parse the result.
identifyimageservice.fmwt
If you need to pass a token with the request, put it in the header as described here:
GET https://arcgis.mydomain.com/arcgis/rest/services/SampleWorldCities/MapServer?f=pjson HTTP/1.1    Host: arcgis.mydomain.com    X-Esri-Authorization: Bearer xMTuPSYpAbj85TVfbZcVU7td8bMBlDKuSVkM3FAx7zO1MYD0zDam1VR3Cm-ZbFo-
You can also put the token as a parameter in the url:
&token=YourToken
