Can FME download the css file from a website?
  • Mar 19, 2019 8:08 AM UTC
  • 6 replies
  • 83 views
liujisheng
Participant
http://m.dianping.com/shop/22242399
I tired the HTTPcaller to download the .css file from DianPing. It returns an error.
lifalin2016
Forum|alt.badge.img+42
  • Mar 19, 2019 8:29 AM UTC
FME should be able to retrieve any resource that can be accessed via HTTP using the HttpCaller. But without the actual url/uri you use to retrieve the CSS, it's rather impossible to comment further. You may also need to set up some specific header information in HttpCaller, e.g. some login or ticket information. In your case maybe also some transfer-encoding information.
liujisheng
Participant
  • Participant
  • Mar 19, 2019 8:34 AM UTC
http://s3plus.meituan.net/v1/mss_0a06a471f9514fc79c981b5466f56b91/svgtextcss/dc63fe513c002f0f6dde345e4bbb7bdf.css
This is the url. I tried to set up the header information in httpcaller, but it doesn't work.
  • Mar 19, 2019 8:42 AM UTC
Unfortunately the HTTPCaller seems to dislike raw responses without any content-type headers, such as is the case when you try to read the CSS from this server.
However, you can use a small Python script instead:
import fmeobjects
try:
    import urllib2 as urlreq  # Python 2
except:
    import urllib.request as urlreq  # Python 3
def raw_get(feature):
    req = urlreq.Request("http://s3plus.meituan.net/v1/mss_0a06a471f9514fc79c981b5466f56b91/svgtextcss/dc63fe513c002f0f6dde345e4bbb7bdf.css")
    contents = urlreq.urlopen(req).read()
    feature.setAttribute('css_contents', contents.decode("utf-8"))
The output feature will have a new attribute css_contents containing the raw text returned by the URL.
liujisheng
Participant
  • Participant
  • Mar 19, 2019 8:45 AM UTC
import fmeobjects
try:
except:
Wow! I'll have a try, thanks very much.
jkr_wrk
Forum|alt.badge.img+37
  • Mar 19, 2019 9:49 AM UTC
import fmeobjects
try:
except:
Could we call it a bug that FME is not able to accept raw content. I tried different settings like tread as binary, write to file, but FME does not accept.
I think that if I say the data is binary FME must accept my settings.
  • Mar 19, 2019 10:12 AM UTC
Yes, that would be my opinion as well.
