Can FME connect to Salesforce Platform Events?
  • Mar 15, 2023 4:06 PM UTC
  • 114 views
crstnaiw
In Salesforce, they have a feature called "Platform Events" where the fields are defined in Salesforce. Does FME have an existing connector or an app for this and can FME also publish changes to the "Platform Events"?
Thank you
Best answer by kailinatsafe
Hello @crstnaiw​, it looks like the SalesforceConnector can access the SF Platform Events API or you could try using an HTTPCaller instead. If you need any help structuring your API call, try using the Salesforce Workbench. Otherwise, we have an awesome tutorial available for: Connecting to Salesforce. Happy to help, Kailin
kailinatsafe
Forum|alt.badge.img+24
  • Mar 21, 2023 6:17 PM UTC
crstnaiw
  • Mar 22, 2023 2:09 PM UTC
Thanks for this info @kailinatsafe​ , I am new to both FME and Salesforce, I will try this out! :)
