AzureFileStorageConnection 4.2.1 issues
  • Dec 8, 2025 9:31 PM UTC
  • 95 views
jdh
Forum|alt.badge.img+41
I already have a support case open for this, but I’m curious if anybody else is having credential issues with the AzureFileStorageConnector (Azure Storage package 4.2.1)  in FME 2025?
I’m getting the error message:  AzureFileStorageConnector: Connection 'xxx Azure Storage' does not exist. Check connection parameter and connection definitions in FME options and try again.
Creating a new web connection does not solve this issue.
desiree_at_safe
Forum|alt.badge.img+24
Hi ​@jdh! I see you’ve opened a support case with us. We’ll continue to troubleshooting with you there and address the community once it’s resolved🙂
But thank you so much for sharing this with the community! It could provide more context and guidance to other user cases that might be facing the same issue
[Internal note: ZD #60546]
