Autodesk Build connector
bbo
Forum|alt.badge.img+3
Is there a way to connect to Autodesk Build and retrieve photo's and Forms? Either through a connector or through the API. I can get acces to Autodesk Docs but I need acces to Build as I would like to add the photo's to a webmap.
Because the API acces to ACC Build makes use of a three-legged authorization I see no possibility to do this. The process needs to allow for a pop-up and I don not know a way to avoid this. I hoped it was possible to use a webconnection in conjunction with an httpcaller but I do not know how.
Does anybody have experience with this and perhaps an example?
hkingsbury
Forum|alt.badge.img+51
  • June 21, 2024
bbo
  • June 26, 2024
@hkingsbury I have tried to use the oauth2 webservice. But my my knowloedge of this is limited. And I struggle with the part in where the refresh token parameters are entered.
As Autodesk Build uses “3-Legged Token with Authorization Code Grant” I do not know how to get the token with the authorization code.
Has anybody succesfully connected to Autodesk Build API? If so I would love to hear how.
mgg_beca
Forum|alt.badge.img+10
  • March 19, 2025
Hi ​@bbo I have successfully authenticated to the Autodesk Build API to submit forms to ACC using a safe.autodesk-docs.Autodesk Docs web connection.
Cheers,
Marc
bbo
  • March 20, 2025
Hi ​@mgg_beca ,  were you also able to get more then the files in Docs (as in Photo's and Surveys)? At the moment I am only able to connect to ACC Docs and not to the parts only in Build.
BR,
Berend
mgg_beca
  • March 20, 2025
hi ​@bbo,
I use the web connection for authentication but httpcallers for doing the work via the build API.
For example this is for creating a blank form:
using the template ID and project ID from user parameters. Example workflow is here: https://aps.autodesk.com/en/docs/acc/v1/tutorials/forms/create-update-forms/
Unfortunately there are limitations with Photos being read only at the moment which is a shame.
Hope this helps,
Marc
