Archived
AutoDesk Vault Connector Transformer
Related products:FME Form
siennaatsafe
fmelizard
tcrossman
bruceharold
jelle
+16
  • siennaatsafe
    siennaatsafe
  • fmelizard
    fmelizard
  • tcrossman
    tcrossman
  • bruceharold
    bruceharold
  • jelle
    jelle
  • jeroenstiers
  • lde
    lde
  • zander
    zander
  • bakkermans
  • nmiller
    nmiller
  • nielsg
    nielsg
  • louisput
  • kd
  • jneujens
    jneujens
  • qmarquette
  • verdoodtdries
    verdoodtdries
  • mmacfarlane
    mmacfarlane
  • wdh
  • ioannakostara
  • jsc
  • epb7004
fmelizard
Some customers have created custom transformers for connecting to AutoDesk Vault with FME. This idea is for creating an AutoDeskVaultConnector transformer. Please provide feedback in the comments on any specific workflows with Vault you would like to see possible with FME.
<strong>This post is closed to further activity.</strong><br /> It may be a question with a best answer, an implemented idea, or just a post needing no comment.<br /> If you have a follow-up or related question, please <a href="https://community.safe.com/topic/new">post a new question or idea</a>.<br /> If there is a genuine update to be made, please contact us and request that the post is reopened.
jelle
Forum|alt.badge.img+16
  • January 10, 2018
Excellent idea!
At the Belgian railways, we now access Vault with a Custom Transformer, using SQLExecutors and a Python script. With the File Copy Writer, we download the file to a specific location, so we can use it in the next step of the Workspace.
Why a Transformer? I would rather think of it as a Reader. Similar to the Oracle reader, where you can store your connection details for each user. By analogy with the Oracle Reader (where you can access the table list), this reader should access different data folders for the specified user.
The output could be similar to the PATH reader, so you can link it to a FeatureReader, OR it could read the file in Vault directly. Since you are not sure about the format of the data set, I think the first is better.
To specify the right file, we either use the FileIterationID (the unique key of the file in Vault) or the FileName (field in the Vault environment). This could be a parameter in the Reader, so you do not need a TestFilter afterwards.
Who has some other ideas?
jneujens
  • January 10, 2018
1) One of the most time consuming things when reading data from Vault, is finding which file property is stored in which table of the SQL Server database. Once you know which ID's you can use to link tables, retrieving data is just a matter of creating the query. But this is not a very generalized way of working, as the output schema is fixed.
It would be nice if the output of a VaultConnector could be more flexible. Not only use filenames, but also export data based on the creation date, name of the person who created a file, all files within a sub-project, all files that are not approved yet, etc. There are so many file properties available within Vault, so it would be nice to combine all these parameters to tailor your export.
To be more flexible, a new VaultConnector might use the Vault API? I don't have much experience on the API but it might be a good idea?
2) Writing data to Vault might be something to be prudent about. Can FME overwrite files Vault? Change the revision number of a file? How will we make sure that all the essential file properties remain?
fmelizard
Forum|alt.badge.img+19
  • January 11, 2018
Safe PR#81283
jelle
  • January 18, 2018
After seeing the FME2018 Unveiling, I was thinking that a similar mechanism as for the S3Connector would be more appropriate than a Reader for connecting to Vault. The output should be one or more files then followed by a FeatureReader. That probably makes more sense.
daveatsafe
  • January 24, 2018
Perhaps we should have the option to set up a Vault connection in the FME Web connections, then allow the use of that connection when reading/writing Vault compatible formats.
Another opportunity we have with Vault is to use the Job Handler API to create a connection to allow FME to be used as a Vault Job Handler. This could connect to either command line FME or FME Server, and would let Vault users incorporate FME processing into their Vault workflows.
